Hi John, try the size guide chart and see what will fit the width seems wide to me so I would say unlikely.
17 inch may fit however check the guide and see what others are running here on the forum.
Maybe someone else's opinion may differ from mine.
But for the size guide check here and you wont go over.
Main reason is you may experience tyre rub but this depends on your micra how its set up and what other mods if any you are running.
These are the standards for the k12.
I personally am running 15in standard alloys the tyres should have been a little wider with these but the 17in seem to have a more reasonable width.
If you must go with over sizing use a tape measure and test in full lock to see if you get scrubbing or other issues.
