CMF_fred
» CMF Memberyep, I finally got around to putting it in. It took 15min.... so I then put the primera injectors in too. That ended up begin alittle harder. With the GA15 TB in, I had to take the fuel rail out and swap the injectors. then found out that you need to attach the wires to the injectors b4 mounting the fuel rail (due to the size of the Ga15 tb) then it didn't seem right when I started car, it was to lean? then when I came back from going around the block, I found 3 plastic spacers that squarely mount the fuel rail to manifold (obviously leaking air into the manifold around the injector seats), doh! loosen the fuel rail again.... Give an update, later.
