i dont see the point in doing that. this is because the janspeed is larger then your original exhaust, so if the sportex pipe from the backbox to the rear flange is the same size as the original you'll be bottlenecking the whole system. it'll be fine if its the same size or larger then the janspeed though, id have a check first.
