Primal_Concrete_Micra Ex. Club Member Nov 30, 2008 #1 Does anyone else have one of these fitted? Was wondering how you mounted it as there is nowhere for the original rubber mounts from the cat to attach!
jim_bling Ex. Club Member Nov 30, 2008 #2 easiest thing i done was to use the original rubber mounts on the body of the car and put a pole through the place the hanger was then capped the ends off so the pole wouldnt fall off
frank Club Member Nov 30, 2008 #3 primal the bracket is separate, and bolts off, so you just swop the cat for the decat (if you can get the nuts off lol)
