If you want to skip to my actual problem, read the bold text
But there's already some problems.. So one of the injectors seems to be dead but finding a new one is pretty frustrating. I won't buy it brand new, would make sense if my micra would be in a good condition & clean, but it has seen some life.. Anyways I've called thru sooo many of the scrap yards here in Finland.. No luck so far. Basically when they get a micra, the injectors are gone instantly. Checked some private sellers aswell, injectors always gone. But let's put that to side for a second and focus on my another problem. So I removed the fuel rail yesterday, sprayed with some air (for some reason) and today I put it all back together. (Bought a new air filter too, the one it had was pretty much black) Like an ass I am, I didn't think about marking the tubes/hoses/pipes whatever you want to call them, and kinda forgot what is for what. Might have gotten the ones going to the fuel rail mixed, could anyone tell me which way they were, one had some red in it, you know what I'm talking about I'm sure. So after putting it all back together I tried to start it, that's when weird things happened. everything electric works fine until I actually turn the key all the way to start it. When I do that, my battery dies (everything, including the little digital clock turns off) and after a short while the power comes back. Sometimes it came back by tapping the red wire going to the battery.. I don't think it could be a problem with the attached wire on the battery because it only does it when trying to crank the engine. IMPORTANT EDIT: It cranked just fine YESTERDAY so obviously i've done something bad but not sure what!
I'm PRETTY sure I have all the stuff connected correctly but there's still a good chance it's not. There was one hose that I couldn't find a place for, a semi thick one that looks like J basically.
Like usual, sorry for this wall of text, any help is greatly appreciated!
