Is this temp sender correct ?
CMF_Petros047
Hello
I am trying to reduce the fuel consumption from my K11 cg10de 99 model micra,now it is over 8lt at 100km mixed.
I change the lambda sensor and also I want to change and the temp sender.
In my country I found from this brand this sensor
http://www.meat-doria.com/en/product_hoffer/7472036/4112
In description write from 1992 to 2000 k11 but is red color
Also the same brand have and that connector
http://www.meat-doria.com/en/product_meat/82115/4112
This sensor is the same color as oem the specifications write that is from 92 to 2000 but also write this:
TecDoc Engine Number: 4700
From construction year: 01.1996
But my only choice is the red version do you believe that is problem to use the red sender?
Or is better to buy one online?
Thank you
CMF_Petros047
you mean if I have test the old one from my car or the new who I have found?
I have install the new it is so cheap 8 euro so i try it.
Before install it I measure the resistor from oem nissan sensor and from the new one and have the same resistor about 2.1kohm in 17 Celsius So I install it to my car i drive it for 60 km everything normal I check and the fuel consumption if is better.
