Toady my 2010 dci ntec returns 100 miles on a tenner! That's a mixture of motorway and local roads.
The onboard trips A and B are reset every time i fill up, i only use Sainsbury's diesel no fandangly stuff.
The mpg on show never dips below 71 in winter and never under 79 / 80 in summer, however i don't believe them figures.
I have previously filled up, driven 100 miles and filled up again to see how much toady drank, It was £10.65 if i remember correctly.
I would suggest you give yours a full service as i have used all oem parts.
Fuel filter
Engine oil
Oil filter
Air Filter
Pollen filter
Coolant
Brake Fluid
Gear box fluid
Also go for 15 / 20 minute drive, pull over and touch your alloys one by one to see if any are warmer than the others. This is to determine if you have a sticky caliper / binding brake etc.
What does your onboard mpg show?
Could also be your driving style, i take it nice and easy and let her / him pick up speed gently as opposed to full foot down!
Thank you for your reply and the great advice on offer.
It was serviced just over two weeks ago by the Honda dealership where I bought it from so I am hoping that they would of followed a fairly high standard of servicing, but saying that you never know with main dealers.
The recent drive consisted of about 97% motorway on my recent trip of 230 miles, with a very small amount of town driving, and the trip computer was showing between 50-60 mpg which when I fuelled it back up and did the formula of miles divided by actual gallons used came out at 50mpg.
On the motorway I stuck to between 65-70mph for the whole trip with the very odd bit of overtaking and the revs was at 2600 (which did seem a little high) at 70mph but that may be the norm so I am not sure.
While the engine is smooth, as it has only done 46000 miles, the clutch is high so I am not sure that the clutch may be part of the issue as in 1st and 2nd gear the revs rise very quick to get it moving. I don't really give the car much stick and in terms of acceleration I am pretty much like yourself with letting it build up speed.
Also I have just used my engine diagnostic tool and it does come up with a trouble code of P0670 which is a Glow plug module control circuit malfunction so not sure if that is a contributing factor.
I will check out the alloys when I am out in it again as you could be right and it could be the brakes binding which is a great bit of advice.
I just wasn’t sure if it is me thinking the worst or if there is a problem that I need to take it back to the dealers about as I am still in the 30 day window of ownership.
Any further advice or thoughts are very much appreciated.
