H Hazara Aug 10, 2013 #1 Hello everyone, Here is the rear wheel spin and here is front wheel spin. Both front wheels ate like that. If it binding then what shall I do? Service the caliper or replace them. Please help. Regards
karlj Aug 10, 2013 #2 Best to take it for a short drive, only a mile or two then put your hand on the centre of the wheel. If it's hot then it's binding
OP OP H Hazara Aug 10, 2013 #3 karlj said: Best to take it for a short drive, only a mile or two then put your hand on the centre of the wheel. If it's hot then it's binding Click to expand... Thanks karlj, I will try that. Regards
OP OP H Hazara Aug 10, 2013 #5 karlj said: No problem Click to expand... Drove 2 miles and touched the disk it quite warm bordering hot. Is it dangerous to travel on motorway for 100 miles? Regards
karlj Aug 10, 2013 #6 You don't touch the disk, cover the nissan badge with your hand You'll be fine driving 100 miles but if you're unsure get them checked at a garage
OP OP H Hazara Aug 10, 2013 #7 karlj said: You don't touch the disk, cover the nissan badge with your hand You'll be fine driving 100 miles but if you're unsure get them checked at a garage Click to expand... But that is the cover and there is vacuum space and it is plastic. It was cold. Regards
karlj Aug 10, 2013 #8 If the calipers are sticking it'll heat up the disc to a point where the disc will heat up the wheel, thats what I said to touch the wheel
Enuo Glorified Electrician Aug 10, 2013 #9 Unless it's REALLY binding, it'll more just reduce fuel economy, but if its binding quite badly it'll limit your braking capacity somewhat
