Hey people.
So I have a K11 '95 (Aus) that's an intermittent no start though it's a bit more permanent these days.
The problem is fuel, the injectors won't fire, I have NATS but it seems to be functioning as you can't even crank the engine with it armed.
She'll idle if I pour fuel down it's throat.
There are no fault codes and all the fuses and relays "seem" to be ok though I'm planning to check all these again.
I recently replaced a chip on the ECU and the car fired up but the next day same no start.
Is this NATS malfunctioning or is there somewhere else I should look.
