Hi I have a micra s, and I am having trouble with my micra
1. I have a problem with the dials intermittently when the car has been started. The petrol gauge shows empty (i know i have a full tank), and rev meter either shows no revs or high revs when car is at idle. If you turn off ignition and then turn it back on they work fine. Also this doesn't happen every time you start the car, it can be months before the problem occurs again.
2. the radio doesn't always power up when car is started, but there is power there as the backlight is on, I think this may be a loose connection. But when turning ignition on at it powers up then once you turn ignition to start engine it goes off and doesn't come on :S
Any help and advice would be much appreciated.
