Good morning all
Just bought an 08 plate micra auto for my elderly mother.
Starts and runs fine, she likes it, apart from an intermittent electrical issue...
At times, everything works fine.
Then, for no apparent reason....
The nearside indicators react with the nearside brake lights, alternately flashing. I've changed the bulb, no change.
At the same time, the key wont operate the central locking remotely (new battery was fitted to key). The button by the handbrake operates it ok.
Now .... this appears to be controlled by the heating (climate control) system.... there are times when you leave the car with it switched off, only to return to find everything on and the fan blowing full blast.
Fiddling with the controls here, at random, can change the state of the rear lights/indicators/locking from working to not working and vice versa.
When nothing is working, and with the key removed from the ignition, there is a flashing key symbol to the left of the speedo. Sorry, cant remember if this is flashing if the other systems are working.
As an aside, and I dont think related, the rear parking sensors have never worked.
I'm lost. It is going back to the dealer on Thursday, but obviously everything will work fine for them....
Any ideas?
Thanks all.
Any ideas?
Thanks all.
