cisco
» CMF MemberIn you have an aftermarket shifter knob, you can try re-installing the factory one. Part of its design is being solid, heavy rubber which helps dampen vibrations coming from the gearbox. A lot of the aftermarket ones are very light and get thrown around too easily making vibrations come through or sound louder.
After recently solving my shifter rattle, but it coming back a tiny bit within the past couple of weeks, I tried this yesterday.
It has definately reduced the volume of the rattle noises, however not eliminated them. I also noticed that the shifter is smaller, so the shift throw ends up lower/shorter compared to the larger aftermarket item.
So I'm quite happy with it, and it feels like an upgrade in removing this aftermarket item and going back to factory!
There are so many subtle design features built into factory items that you don't even notice.
