Hi,
The problem is that from time to time the dashboard instruments, speedometer, rev counter, fuel and temperature indicators all fall to zero when driving.
I have checked and reseated the dashboard fuse; cleaned and tightened the battery connections; and I have removed, sanded and reconnected the negative earth lead to the chassis so that it makes a good earth connection. Problem not fixed. Any help would be much appreciated.
Thank You.
Thank You.
