Hi. New to this, so apologies in advance for protocol breaches and thanks for any advice that anyone may have. My otherwise excellent June 2000 K11 1.0 litre petrol Micra has recently started to have instrument problems. First of all, the fuel gauge started showing empty, then the speedo started flicking about all over the place and the same with the temp. gauge, then all instruments died altogether, with only occaisional and increasingly rare guest appearances. All fuses and instrument panel lights (including low fuel) are intact. The speedo and the temp gauge have come back (but still with minor random flicks/outages) after I had the instrument console out but the fuel gauge is still dead. The fuel tank float pinouts give 70 ohms full and 200 ohms empty and there's 12 odd volts on the loom connector to the float when the ignition is on. I tried to get a wiring diagram from my local Nissan dealer but no joy there and I'm keen to find out what pin does what in the instrument console 28 pin connector. Or, even better, does anyone else have any experience of this fault and know what the problem is. All advice much appreciated
