Can anybody tell me if the instrument cluster from a K11 1.3 will fit a K11 1.0?
I know it will physically fit, but are the wiring looms the same and will there be a connection available on mine (1.0) for the Revcounter?
dizzy or coil pack engine?
the looms are the same, but on the dizzy engines the ecu has no knowledge of the engine rpm. On the coil pack engine, its plug in and working tacho straight away.
I've fitted the instrument cluster and all works ok.
Sileter is quite right, you must make sure that both are digital and it is simply a case of swapping over.
