Installing After market Tachometer???
CMF_antish_r
what is the brand of the gauge anyway
the colors are
red = acc
yellow or orange = + constant power
green = signal
black = negative
white = illumination
if you post a pic of the gauge and its color wires might be able to help you out kouchi
CMF_Brendon
to get the rpm reading. tap into a wire on the distributor. on my old car it was light blue wire. on top of distributor so easy to find. for lights i just tapped into the lighting switch and power from the stereo accesory power. earth put it wherever you want. pretty simple.
CMF_frank2
1300cc WROTE:
"anyone have tried connecting the signal direct to the ecu instead of the distributor?
it should be a blue/black wire on pinout # 2 i believe
CMF_frank2
1300cc WROTE:
"frank, so the L/B WIRE at the back of the cluster is not connected at the moment..so it need to be link first, right?
my 2 cars have the l/b wire from the loom connector near the ecu to the cluster, but there,s no short link wire from the connector to the ecu plug :)
CMF_1300cc
frank2 WROTE:
"1300cc WROTE:
"anyone have tried connecting the signal direct to the ecu instead of the distributor?"</div>
i can see the L/B wire from the cluster but cannot see it down below the white connector thing...
