Hi, I am looking at a sat nav/stereo unit from a 2010 K12 to fit in a 2005 model, I am pretty clueless when it comes to this, would it be a straightforward fit?
You will probably need the front facia.
Have not done this but others have, an Oe version will most likley be a simple swap over.
The reason I have not is because the front facia is not easy to find in cabin colour G.
However most I've seen are in black finish.
Good luck with your project I think it is worth while item to change.
If you go on search you may find that others have done the same. As far as I know it should swap over without problems.
