hopefully the planet gear has,nt slipped down inside
you might need to reshape the circlip so that it does,nt snag eh
If the circlip is bent then just reshape it. And when i insert the driveshaft i make sure the gap on the circlip is at the bottom as its easier to slip in
thanks for the help. my circlip is bent so i took it off and the shaft slid into postion perfect.
do i need to close the circlip as i install it.
