Hi Guys,
putting together a new inlet set-up for my micra, have had a couple of issues when trying to match up throttle body with my loom,
This plug wont attach to the corresponding plug (below)
5 pins on the loom - 3 pins on the TB
recent developments have led me to believe that the TB won't attach to the coilpack loom, =(
Have just received the inlet mani with bigger injectors that I was planning to use in conjunction with the GA16 TB & airbox, and I'm wondering whether I can swop over a sensor from one to the other/ do some wire cutting & taping to get the signal through or whether they are incompatible, there is another plug on the K11 TB too with 2 pins but there isn't a corresponding plug on the GA16 which does lead me to believe that they wont be compatible.
I was looking at race spec TB's online etc but when a new K11 one will set you back £100 i think the performance spec will be well out of my budget.
Reading through ebbdudes thread and am considering the dremmeling of the butterfly blade, and I like the idea of the spacer but there isn't enough height clearance under my bonnet for that.
I really do want to avoid using an induction kit to level out the afr while using the injectors but if there's no other option open to me, I suppose I can be persueded.
just kinda hoping that someone might have a couple of idea's, would a newer model TB off a more recent GA model engine do the job do you reckon?
