Quick question:
As part of their Nissan Micra K11 GSX600R throttle bodies bolt on kit, Danst Engineering sell a set of '4 x Injector Plug Connectors for terminating the injector loom' - this has confused me.
My question is, when fitting my GSX600 bike throttle bodies, I want to use the bike injectors rather than my stock Micra injectors. So, how I do adapt the Micra injector loom to connect to the bike injectors or will the stock Micra injector plug connectors fit directly onto the bike injectors?
Or will I need the injector plug connectors that Danst are selling?
Also second question - can a coilpack 1.0 ECU be remapped into a 1.4 ECU? (I already have my old 1.0 ECU lying about so I could send this off to Tornado systems for remapping rather than having to remove the 1.4 ECU which is already fitted in my car)?
Connector for Suzuki GSXR1000 Keihin Injector Connector Plugs (x4)
danstengineering.co.uk
