Info needed
CMF_Mimz
1. Got a leaking CV boot on passenger side. I have remove the drive shaft, where in melb can i take it fix or can i just buy the boot and fix it?
2. With regards to the attachment of the speedo cable to the gearbox, is it just hold on by one 10mm nut? any special way needed to remove it?
CMF_frank2
c/v removal was covered recently mimz, and the cable screws onto the speedo drive fitting, and that fitting slides into the top of the diff/gearbox, and that drive fitting has a tab where the 10mm bolt holds it in
