emmet_gti Oct 10, 2010 #1 my indicators arent working after i tried getting my cd player working, my hazard lights still work and none of the fuses at the right of the steering wheel are blown, is it possible i fried my indicator stalk?
alexzaki Oct 10, 2010 #2 I would also check the relays. Any other ideas guys? Hope you'll figure it out. Alex
OP OP emmet_gti Oct 10, 2010 #3 where are the relays? i would have thought that the hazard lights wouldnt have worked then?
frank Club Member Oct 10, 2010 #4 there are a few threads on here about blowing fuses after fitting a HU, (earth problem iirc) i would disconnect the stereo and doublecheck the fuses
OP OP emmet_gti Oct 10, 2010 #5 i did already, thats why i was askin is it easy to fry an indicator stalk on a micra
fob12 Oct 10, 2010 #6 Are you looking for the relays i have a hynes manual it might help you just tell me what your looking to try and diagnose
frank Club Member Oct 10, 2010 #7 the fuse is the 2nd one up on the left on mine emmet, and if i pull it the indicators dont work but the hazards do still
OP OP emmet_gti Oct 10, 2010 #8 ok thanks frank ill have another look again, ive a march so the fuse diagram is in japanese
S Scott My name is Scott Site Supporter Oct 14, 2010 #11 Did you ever get this problem solved? My grans car now has the same problem and i'm hoping its an easy fix.
R RR_dev Site Supporter Oct 26, 2010 #12 Sjackson said: Did you ever get this problem solved? My grans car now has the same problem and i'm hoping its an easy fix. Click to expand... Bump for this...
Shaun ***StaGGeRed*** Oct 26, 2010 #13 Did you disconnect the battery like a good boy? :doh: also even if the fuse seems fine change it anyways could be a small crack in it still.
S Scott My name is Scott Site Supporter Oct 26, 2010 #14 RR_dev said: Bump for this... Click to expand... You said you sorted it....
