Indicator/grille swap; another n00b question
Hi again and thanks for advice regarding my other questions.
Another noob question here...I have an 03 k12 micra with the bog standard headlights and orange indicators. Is it as simple as a straight swap to remove the current indicators and grille to the more modern facelift clear indicators and grille?
Similarily, is it a straight swap to change the headlights and side repeater indicators on the doors to facelift smoked ones?
cheers
sharpy
Umm yes ^_^
They can be swapped @Guy swapped his '09 facelift front grill for an original uk spec '03/'04 style one
Another member @MicraSport swapped their headlamps from the '03/'04 style to the later '08/'09 facelift style ^_^
I have the "smoked" (black reflector) '05 facelift headlamps and clear front indicators.
Do remember you may need to change from clear to amber bulbs depending on which grill/indicators you go for
