Bit of an odd one, randomly the indicator flashes fast as if a blown bulb warning is there. Every time we check all the bulbs are fine. I've cleaned the bulb contacts and still randomly it was doing the fast flash.
MOT time a few weeks ago and it failed on rear sidelights changing brightness when indicator or brake came on. So fixed that by attaching a heavy earth wire from light loom earth to the body - lights were fixed and not a flicker from the sidelights now. MOT passed with perfect lights.
The random indicator still happened, but we've since found that the fast flashing happens when the indicator is on and brake pedal is pressed. So, the question is, what detects and controls the fast flashing fault condition?
Where or how does it sense a bulb out?
And what unit decides to make the indicator flash fast?
