whatever is safer. ive been searching the internet and some saying it will definitely improve power, but some says it will affect the thermal efficiency of the engine
nah, you worry too much lol, the engine ran ok with the 3mm headskim (and a 260 cam), but it made the lower chain too slack (spark/cas signal jitter at idle etc) i ended up running with 2 head gaskets and the lowest mile chain i had (the blue car,s engine).
but 1.0 pistons are a neater solution tbh, and a cga crank so that you can run 2 gaskets and have a nice tight chain
You must have a very specific cam choice in mind I assume. Compression that high can lead to more problems than benefits and could actually make less power than with something safer like 12:1.
keep the money in your pocket paul... you're better off keeping it stock, work on light weight and finishing your exhaust...hows the panhard comming? btw have a jdm k11 head if you want to start a project.
