hello all,
im new to the forum but not new to k11's.
had my first last year:
Then as my other project planned to come off the road i purchased (as some may know) Dougs Panda 1.3
Right now where i need help!
basically i was informed of a small leak, so by the time i got it home there was little water in it and so took what was left out, cleaned all the pipes etc and put back together and it was fine, no leaks, however then it started overheating, so got it properly bled, yet still overheated, turns out i put pink coolant in with blue, so dumped the lot and started again with pink, still overheats,
it cant be thermostat because all pipes are warm, the fan didnt work before but now have it with a switch in the dash which helped, night driving was fine unless your ripping it.
thought it could have been headgasket as it was blowing bubbles into the expansion tank so got some steel seal and followed the instructions, but then havent 'properly bled' the ater system as i am really unsure on how to do it.
then like an idiot (however think its neccesary to mention) i ran it up the road forgetting i didnt have the oil cap on, so again it got hot, filled it up with oil then put the cap back on and its still getting hot
really unsure what it was, then last nights its started bogging, when last night when to start and it struggled, wont tick over properly, and is really boggy to drive, lost alot of power and is quite poppy on the exhaust.
i have no idea whats up with it and im ready to drive it into a tree.
i bought this micra because i knew it was done peoperly and looked after but....
ANYWAYS! i need all the help i can get as i need to get to london in it on friday night, as then the next day going to europe.
half tempted to take it to a garage but thought i would ask you nuts first!!!
ANY HELP WILL RECIVE VIRTUAL BEER TOKENS!
THANKS
THANKS
