Hi im sean new here,
Well its actually my brothers car.
Its a 98' R reg 1.0 16v K11.
The other day its just wouldnt start and the check engine light was flashing.
First thing i did was check for spark - there is a spark
Then - fuel, no fuel! But the car was low so i changed fuel filter and put some more in. Still nothing.
I then using Autodata seen that a paper clip across the two pins will reveal the code.
I got 141 and 146 both appear to NATS related as far as i can see.
I just unplugged the ignition ariel and it started for about 5 seconds.
Done it a few times and then it wont start at all again now.
Is it likely to be the ignition ariel or the ECU?
Were is the ECU lol, i found the airbag one behind the console. I can not for the life of me find the engine ECU though lol.
What do you reckon ?
Thanks in advanced,
Sean
Thanks in advanced,
Sean
