Hi
My 1992 K10 failed its MOT last week with imbalanced front brakes of 42%.
With close inspection I found the N/Side had a seized caliper guide pin, which I have now repaired.
While I was on the job I replaced the brake fluid at all for corners as the fluid was turning a shade of brown.
The pads are like new but the discs are quite worn.
Do you think I have solved the imbalanced issue ? as without rolling road testing I shall never know.
Many thanks
Deano
Many thanks
Deano
