does anyone knows how much if i have to get all this done?
1st test
Reason(s) for refusal to issue Certificate
Nearside front position lamp(s) not in good working order (not working) (1.1.4a)
Nearside Front headlamp not working on main beam (1.2.4a)
Nearside Front headlamp not working on dipped beam (1.2.4a)
Offside Rear OUTER SILL suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Offside Rear INNER SILL suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Nearside Rear FLOOR suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Nearside Rear OUTER SILL suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Nearside Rear INNER SILL IN 2 PLACES suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Offside Front INNER SILL suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Advisory Notice issued
Fuel pipe/s corroded
Engine/gearbox mounting(s) defective
FRONT VALANCE AND ENGINE MOUNTING CORRODED **DANGEROUS**
2rd test
Front vehicle structure has an unsatisfactory modification, seriously affecting its strength within 30cm of the body mountings (6.1.3)
Front vehicle structure has excessive corrosion which adversely affects braking or steering (6.1.1)
Nearside Front tyre has a bulge, caused by separation or partial failure of its structure (4.1.C.1b)
Offside Front headlamp not working on dipped beam (1.2.4a)
Offside Front headlamp not working on main beam (1.2.4a)
Nearside Front stop lamp not working (1.3.2a)
Rear registration plate lamp not working (1.1.5c)
Exhaust emissions carbon monoxide content at idle excessive (7.3.2c)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.2b)
Exhaust emissions hydrocarbon content after 2nd fast idle excessive (7.3.2b)
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.2b)
Corrsion fuel pipe leaking (7.2.1a)
Offside Outer Front front constant velocity joint gaiter split (2.5.C.1a)
Brake load sensing valve linkage seized (3.6.F.3)
Exhaust emits blue smoke during acceleration (7.3.A.1c)
Exhaust system has a minor leak of exhaust gases (7.1.2a)
I have to say i know nothing about cars, feeling sad now might need to scrap it, i didnt know it went to mot just few day ago >.< i thought it would be a brillant car, sad to say goodbye in just a day, anyone in manchester knows where i can get all fix at the lowest possible price thank you!
1st test
2rd test
