CMF_ChrisB
» CMF MemberHi,
I have recently had some problems starting my micra, which I think is either to do with the ignition switch or barrel. Basically my car will only start when I turn the key very slowly, if I do it quickly it will not fire up. It has to be turned very slowly passed the on and then held in that position. Also a couple of months ago I had some problems with the battery draining itself, but this seems to have stopped now. Is this a possible sign of a faulty ignition switch or is it more likely to be to do with the ignition barrel.
THanks alot for any help
