Hello all, I do apologize if you all think that I have posted this in the wrong place but here goes. I have a Nissan Micra K11 engine which is not in a car. The car was scrapped. It was an 02 car. I want to run the engine and the engine is connected to the harness computer and ignition key assemble. It is exactly as it would be if it was in/on the car. The only thing that I do not have is an ignition key. Can anyone tell me how to get the engine running. I would think that I would be able to start the starter motor easily enough but how to get past the transponder situation is the problem. I assume that the ignition key/transponder etc sends a signal by wire to the computer but do enlighten me if I am wrong. As I just want to run the static engine the security etc that goes with the ignition system is not required. As I am sure that one of the experts on this site has worked it all out so I thank you all for the information that I am sure will be coming.
