nathan.warren69
Hi Guys,
Im in the middle of trying to hook up my tacho, Ive connected up the power to it but im having trouble connecting the signal cable, I have an 02 plate with coil packs,
Where would you say the best place to connect the wire to is?
I dident have much luck with trying to find it from the ecu or the OBD port so im now going to try the coil however i cannot find where it needs to go, and also where is the distributer? would I be able to connect it to this?
Thanks in advance.
Thanks in advance.
