I
ian1820
hi there just new to this so bear with it pls!
i have been having problems with starting my micra, i have (eventually!!) traced the fault to the ignition switch at the bottom of the ignition barrel, the switch was not staying on and the car was cutting out after it had started i could keep it running by holding the switch in position! i eventually had to hold the white/black wire (from the battery) onto the white/green wire to get home after breaking down in the middle of nowhere. the next day when i went to fix the problem there is no power from the white/black wire and all fuses and fuseable links are ok! what have i done? i am going to buy a new switch but it wont do me any good if i dont have any power to it! all the lights etc work so the battery etc seem ok
any help greatly received!!!
thanks
thanks
