Idle ------------
Can anyone please tell me on the K11 rev counter where should the needle be idling on?
like most cars would be just under the 1 on the rev counter which should be roughly 800-850 rpms?
Seems like my car was running low and sounds abit rough until i sprayed carb cleaner to clean the maf sensor, sounds better now but need the idle set up correctly.
J
Mine idles like 500 rpm... between the first and second line from the bottom... no problem at all :) but yeah the above comment should be what it does...
Hi guys thanks for your replies, as picture below shows a white line so its where the needle should be then.... makes sence.....
Also when adjusting the Idle, do i disconnect the idle valve plug from the throttlebody then adjust the idle screw and plug back the idle control once done?
J
