In the interest of furthering my knowledge of car electronics, I've bought myself a new toy. To check idle RPMs, the manual (if you can call it that) says connect black to "-" battery post, easy enough, and red to "-" coil wire, not so easy. The coil, apparently, is inside the distributor. Haynes says take distributor out and dismantle to get to coil. Obviously, car won't run without a distributor. Anyone had any experience with setting idle RPMs with this sort of meter?
S
S
