Does anyone have a picture of the idle adjustment screw on the throttle body for a 1.0l non-coilpack K11. I just need to make a slight adjustment as it is 400rpm above what it should be
when cold or warm?
normally it should fast idle at 1300-1400rpm when cold and as the temp gauge rises to middle, the idle should also gradually lower down to 750rpm when fully warmed up.
if it doesn't fast idle when cold and slows down when warm, it could be a sign of an old seized waxstat fast idle mechanism and/or dirty or seized Idle Air Control Valve.
the waxstat is at the rear corner of the TB. coolant runs through it.
when its cold (or permenantly seized), it allows the sprung mechanism to push the throttle slightly open to speed up idle.
when its warm, it expands against the sprung mechanism to allow the throttle to fully shut and slow the idle down.
the electronic IACV at the front of the TB does pretty much the same job.
when the ecu see's the coolant is cold, it opens up the IACV to speed up idle.
when its warm, it closes the IACV up.
the later facelift bosch TB removed the old waxstat prob cos they tended to seize and so let the IACV do the job.
my usual remedy for the old preface TB is to
remove the sprung waxstat mechanism (allowing the throttle to fully close),
adjust the TPS to read 0.52ohm when the throttles fully closed,
clean n free up the IACV(maybe also recalibrate it if possible),
fully warm the engine,
then adjust the idle bleed screw to 750rpm warm idle.
once fully cooled down, start her up n check it cold fast idles and then returns to 750rpm when warm.
wrote a guide here
http://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-19#post-446256
