just wondering what are the best mods to make my 1.0 k11 micra faster like can you get manis ect ect. second hand cause i dont have budget for spanky new ones, links would be great
mate you only need an engine as you can bolt the flywheel and clutch from your 1.0ltr onto the 1.3 and use the 1.0ltr gearbox. you should be able to pick one up for no more than £130 bargain
I dont see why not. Re-use the same loom so long as you keep the 1.0ltr altenator on there too. Ive put a 1.3 gearbox in mines and ive got no reverse light now cause the original loom and cg13 gearbox connection are different
The ecu will work good. If you have a pre 1998 without nats you can straight swap the 1.0ltr and 1.3ltr non nats ecu's around. And they normally come up, i got my most recent engine from here 6 weeks ago.
