Defo needs a relaySo how have you ruled out that 3 stalks are broken? Im sure fuses and/or relays need fitted in order to make the fogs work
Front fog stalk on facelift k11's, I know, I have one. And it worksthe stalk switch is for the back red bright light.
i never seen k11's with front fog here in uk,,,,or them having a switch, they is high beam driving lights ?????????
Sorry Have you fitted the relay in the dash fusebox? Checked fuses? It seems a little odd that you can't get any to workThanks a lot just rub it in
Invent what?when did you invent that ?
go aheadInvent what?
