CMF_russell_nash
» CMF MemberHi, I lost my key so I first hotwired it then replaced the key ignition it with flick switch for "on" and a push switch for "start" as a short term measure. This worked fine for week, but then I went to start it and the battery was flat. I tried a replacement (second hand) battery form the scrap yard, which they claim was nearly new, it looks it, and they said had been charging all day. This worked fine but the next day I have the non starting problem again. Do you think my wiring a replacement ignition has shorted something which is draining the battery, or is there another explanation? My wiring is pins 1 to 2 to 3 to 4 to 5, using the Haynes manual wiring diagram. One possibility is that having the acc shorted all the time has drained it, but I don't see how if everything is turned off? Thanks.
