I am the proud owner of a new project.
Its a T reg K11 two door in VERY yellow, sounds good so far ?
Its a non runner with some bits in the boot and a worrying amount of bolts just loose in the passenger footwell with their origins unknown, however when I say non runner it will fire up with easy start, it also has clean oil and holds coolant, no sludge under the filler cap.
One of the bits in the boot is the set of black plastic inlet tubes, possibly the cold air inlet assembly that goes around the battery,another other is the exhaust heatshield.
The final bit in the boot is a trim item I cannot find a home for.
The odd thing about this car and the main reason I bought it was the fact it has been in dry storage since 2007 !
No rust evident, rear subframe looks good, nothing at all at the read end of the sills.
Its just dusty and grotty in need of major TLC
What I could use is a bit of help identifying the bolts I have to find homes for and work out what the empty connector behind the OS headlight is for.
Pictures to follow when Flickr is working again
If anybody has a tidy pair of front seats for a Two-Door please let me know.
Clean and matching would be great, the current ones do not match and contain too much biological material.
