Hi,
Whilst driving the car today, I noticed that the HVAC system was not putting out as much heat as I would have expected. Thankfully I ruled out quickly the coolant system being the issue and narrowed my search down to the control cable that links the heat control knob to the air mix door. The give away was a binding sensation with the knob itself at the half way point.
Looking underneath the dash, I could see the control cable was not firmly attached to the clamp and thus resulting in the arm not being thrown correctly.
Now, fixing this seems fairly straight forward, fully detach the cable from the clamp, adjust the control to the coldest point, and re-attach. However, Nissan do not give the position or sweep information they expect the air mix door arm to take so positioning seems a bit of a guess?!
Does anybody have any pictures or description of the full cold, and full hot position before I go and re-contort myself back into the footwell and attempt reach the dam thing (ideally, without having to remove the full dash!!)!?
At the moment, full cold for me seems to be all far left as far as it will go, more left than the image below seems to suggest. In the service manual, it seems to suggest that the position is more central for full cold, with it being pulled to the right for hot?
From the workshop manual....
