CMF_turbo march-rolling shell
» CMF Memberhello there, just wondering if anyone would know how you could raise the factory rev limit on a stock micra computer? is it possible without a chip/ ep rom?
micrat WROTE:
"why would you want to raise the rev limit anyway?<BR>power starts dropping off well before the factory limiter, so there is no point in reving the poor engine any harder.<BR>the only time that i would think that you would want to raise the rev limiter is if you increased the volumetric efficiency of the engine- head work, bigger cams, increased compression ratio or possibly boost, and then you would want stronger valve springs and other internals if your to rev it much higher.<BR>if you are going to spend the money to do all/some of these to benefit from reving the engine higher(to make more power) then i suppose an aftermarket engine managment system should be within your budget.
solarice WROTE:
"as mentioned it is possible to "hide" the revs from the ecu by blocking a cutout in the dizzy...if you dismantle it theres a metal disc with two openings, its one of those you need to block up or get a replacement made with just the one cutout... (at least thats how i believe its done)<BR><BR>ive never tried this, but have read/heard it works...how long it works will depend on how you drive the car, as they'll be no cut off so id reckon blowing the engine would then become very easy.
turbo march-rolling shell WROTE:
interesting... so in theory.. i could get rid of the factory limiter all together with this... and then possibly install the bee-r rev limiter to set my own!?
