Hi i got a problem with my fog lamp switch on my stalk i was thinking of going to the scrap yard and removing one from a micra how easy is it.My fog lamp only works when i switch on my right hand indicator light on and turn on the fog lamp on. thanks in advance
should be as easy as removing 4 screws under the steering column cowl, remove the upper/lower cowl, , unplug the stalks, remove 2 screws holding the stalk to the column, slide stalk off
