undo the two viable 10mm headlamp bolts, pop the grill panel off (two upper clips, three push clips inside at the bottom and remove the indicator holder. pop out the plastic clip at the bottom of the headlamp, put your hand in under the headlamp and you will feel a 10mm bolt, remove this and with a bit of jiggling the headlamp will com out ! sounds complicated but its dead simple.
