how to remove ecu pins
micra_pete
i know a few of you have had issues with ecu pins, so here is a quick guide to removing them
tools
small pokey device
guide
ecu connector
open cover - prise it up from the side, mind the wires!!!
make yourself a tool, this is about 3mm wide by about 15mm long, made out of an old hacksaw blade
from the connector side, slide the blade in above the pin, at the top there is a tab, the tab needs to be pushed up
pull the wire and the pin should come out, if the wire has snapped, hook something into the pin and pull.
then adding a pin is easy, put it back into the hole until you hear a click, make sure its in the correct way, close the cover.
