hello,
I have k11 1.3 Super S year 1995
and I can't read the ECU fault codes, I tried to connect the two wires for 2 sec on the ign but I cant see any signal
does my car mode has a led on the ECU and is it possible to see it without removing anything (I spent alot of time but I couldn't find the led)
or does a lamp on the dashboard should flash (I removed the dashboard and I couldn't find a check engine lamp I only found NCVT lamp which has never became on and by the way my car has Manuel transmission)
last question what's the color of the obd two wires that should be jumper ed
thank you
thank you
