How to get that screw out?
TriNode
I think the screw I'd have to remove to get the driving lamps out has seized, any tips for not stripping it's head?
it's not the little one you take off first, it's the big inner one that actually holds the lamp in place.
Thanks,
- Ant
Do you mean the one behind the removable strip thingy?
Elbow grease works but you might damage the bumper, if that still doesn't work taking the bumper off may be needed
Yes that's the one, my removable strip is broken, so I guess it's corroded a bit, it's just for changing the bulb when / if it goes, is it doable without removing it? I'm able to twist the back off the lamp, but as I can't see what i'm doing, I can't get any further.
does anyone have to hand a picture of the back of the driving lamps? I might be able to do it without removing the lamp if I knew what it was like at the back (where the clip is etc).
