Had a problem on my daily, this seems to be a common problem: the gearstick doesn't spring back to the middle position when shifting gears! Saw some text guides on how to fix it, and decided to document my progress.
Step 1. Get said car up on ramps/jacks. I used industrial ramps. Here is a shot of the underside, and the bolts you need to remove to get to the assembly. They are 5x10mm.
Step 2. Remove the broken spring.
Step 3. Replace or bend the spring back into original shape. It won't last forever if you bend it, but it's a free fix
Step 4. Picture of spring bent back into shape:
Step 5. Reattach the spring (not pictured completely, my hands were too dirty for the camera :/)
There you have it. A simple fix for a common problem
