How to attach laguna splitter??
joshbl
Site Supporter
I was thinking self tapping screws or something along that line. Not sure about "no more nails"
any help would be appreciated
cheers
I was thinking it would be easier to take it off first. Does that take long? only a plastic one with no fogs
very easy only 10 bolts for the bumper itself, take the grill off then get a 10mm socket and undo the 4 bolts under each headlight, then there is 1 (10mm) bolt at the very end of the bumper where it meets the wing each side, these will be the most awkward because there's the splash/arch guard in the way remove those bolts and and its off
Cheers for your help guys :grinning:
Got it off ebay for £28 which was a bit steep. It's like new but just dirty. You can pick them up from a scrappie for a lot less if you can find one
