CMF_mo386
» CMF Memberhello all
I'm triying to adjest the idel speed on the micra K11 96 model but there is no luck-when the engian start it will do more than 1200RPM and when the temp start to rise the idel will drop to 1000 or 950 Max-I did clean the idel valve re soldering the Th Body but there is no luck-when switching off the engin- it will start high about 20 sec later gose to 960 rpm-when I accelrate to bring it up to 3000RPM and let it go down it will be 1100-seems the automatac chocke it not working any ide
thanks
thanks
